Time Before: 0.01182 seconds
Time After: 0.01505 seconds
Time Taken: 0.00324 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.01516 seconds
Time After: 0.01560 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.01584 seconds
Time After: 0.01601 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.01687 seconds
Time After: 0.01964 seconds
Time Taken: 0.00277 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.01608 seconds
Time After: 0.02504 seconds
Time Taken: 0.00897 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.03045 seconds
Time After: 0.03087 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.03374 seconds
Time After: 0.03501 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.02965 seconds
Time After: 0.03526 seconds
Time Taken: 0.00561 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.05385 seconds
Time After: 0.05401 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.06522 seconds
Time After: 0.06649 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.068539142608643
Time Before: 0.07323 seconds
Time After: 0.07340 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.07553 seconds
Time After: 0.07700 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=57256'
Time Before: 0.09785 seconds
Time After: 0.09809 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.096428155899048 seconds with 9 queries, spending 0.0084083080291748 doing MySQL queries and 0.088019847869873 doing PHP things.
