Time Before: 0.00189 seconds
Time After: 0.00267 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00274 seconds
Time After: 0.00315 seconds
Time Before: 0.00341 seconds
Time After: 0.00364 seconds
Time Before: 0.00468 seconds
Time After: 0.00687 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00371 seconds
Time After: 0.01202 seconds
Time Taken: 0.00831 seconds
Time Before: 0.01452 seconds
Time After: 0.01493 seconds
Time Before: 0.01800 seconds
Time After: 0.01917 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01376 seconds
Time After: 0.01935 seconds
Time Taken: 0.00559 seconds
Time Before: 0.02521 seconds
Time After: 0.02543 seconds
Time Before: 0.02751 seconds
Time After: 0.02877 seconds
Time Before: 0.03269 seconds
Time After: 0.03283 seconds
Time Before: 0.03522 seconds
Time After: 0.03668 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=57298' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.05729 seconds
Time After: 0.05758 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
