Time Before: 0.00157 seconds
Time After: 0.00207 seconds
Time Before: 0.00214 seconds
Time After: 0.00266 seconds
Time Before: 0.00286 seconds
Time After: 0.00299 seconds
Time Before: 0.00363 seconds
Time After: 0.00585 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00303 seconds
Time After: 0.01010 seconds
Time Taken: 0.00706 seconds
Time Before: 0.01234 seconds
Time After: 0.01286 seconds
Time Before: 0.01436 seconds
Time After: 0.01555 seconds
Time Before: 0.01162 seconds
Time After: 0.01580 seconds
Time Taken: 0.00418 seconds
Time Before: 0.02345 seconds
Time After: 0.02361 seconds
Time Before: 0.02608 seconds
Time After: 0.02732 seconds
Time Before: 0.03027 seconds
Time After: 0.03044 seconds
Time Before: 0.03277 seconds
Time After: 0.03422 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=57341' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04692 seconds
Time After: 0.04717 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
