Time Before: 0.02724 seconds
Time After: 0.03566 seconds
Time Taken: 0.00842 seconds
Time Before: 0.03578 seconds
Time After: 0.03620 seconds
Time Before: 0.03644 seconds
Time After: 0.03658 seconds
Time Before: 0.03734 seconds
Time After: 0.03983 seconds
Time Taken: 0.00249 seconds
Time Before: 0.03665 seconds
Time After: 0.04393 seconds
Time Taken: 0.00728 seconds
Time Before: 0.05654 seconds
Time After: 0.05682 seconds
Time Before: 0.05989 seconds
Time After: 0.06108 seconds
Time Before: 0.05550 seconds
Time After: 0.06137 seconds
Time Taken: 0.00587 seconds
Time Before: 0.10693 seconds
Time After: 0.10707 seconds
Time Before: 0.24918 seconds
Time After: 0.25046 seconds
Time Before: 0.26002 seconds
Time After: 0.26016 seconds
Time Before: 0.26287 seconds
Time After: 0.26433 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=57361', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.28185 seconds
Time After: 0.28216 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
