Time Before: 0.00150 seconds
Time After: 0.00202 seconds
Time Before: 0.00208 seconds
Time After: 0.00267 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00289 seconds
Time After: 0.00308 seconds
Time Before: 0.00376 seconds
Time After: 0.00620 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00314 seconds
Time After: 0.00963 seconds
Time Taken: 0.00649 seconds
Time Before: 0.01146 seconds
Time After: 0.01179 seconds
Time Before: 0.01428 seconds
Time After: 0.01553 seconds
Time Before: 0.01080 seconds
Time After: 0.01570 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02110 seconds
Time After: 0.02126 seconds
Time Before: 0.02348 seconds
Time After: 0.02480 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.026846885681152
Time Before: 0.02846 seconds
Time After: 0.02865 seconds
Time Before: 0.03081 seconds
Time After: 0.03235 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1769359824, location = '/forums/private.php?do=newpm&explain=1&u=57401', badlocation = 1
WHERE sessionhash = 'e60efe98bb3a97c417ccaae1b39ae601'
Time Before: 0.04828 seconds
Time After: 0.04856 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
Page generated in 0.047163009643555 seconds with 9 queries, spending 0.0082921981811523 doing MySQL queries and 0.038870811462402 doing PHP things.
