Time Before: 0.01265 seconds
Time After: 0.01804 seconds
Time Taken: 0.00539 seconds
Time Before: 0.01814 seconds
Time After: 0.01864 seconds
Time Before: 0.01898 seconds
Time After: 0.01912 seconds
Time Before: 0.02006 seconds
Time After: 0.02287 seconds
Time Taken: 0.00282 seconds
Time Before: 0.01920 seconds
Time After: 0.02735 seconds
Time Taken: 0.00815 seconds
Time Before: 0.03442 seconds
Time After: 0.03481 seconds
Time Before: 0.03709 seconds
Time After: 0.03828 seconds
Time Before: 0.03374 seconds
Time After: 0.03854 seconds
Time Taken: 0.00480 seconds
Time Before: 0.06196 seconds
Time After: 0.06211 seconds
Time Before: 0.07699 seconds
Time After: 0.07930 seconds
Time Taken: 0.00231 seconds
End call of global.php: 0.081092119216919
Time Before: 0.08452 seconds
Time After: 0.08467 seconds
Time Before: 0.08678 seconds
Time After: 0.08820 seconds
SET lastactivity = 1776614883, location = '/forums/private.php?do=newpm&explain=1&u=5741'
Time Before: 0.10667 seconds
Time After: 0.10695 seconds
Memory Before: 4,288.281 KB
Memory After: 4,288.500 KB
Page generated in 0.10547804832458 seconds with 9 queries, spending 0.0093758106231689 doing MySQL queries and 0.096102237701416 doing PHP things.
