Time Before: 0.03235 seconds
Time After: 0.04245 seconds
Time Taken: 0.01010 seconds
Time Before: 0.04255 seconds
Time After: 0.04304 seconds
Time Before: 0.04329 seconds
Time After: 0.04340 seconds
Time Before: 0.04409 seconds
Time After: 0.04695 seconds
Time Taken: 0.00286 seconds
Time Before: 0.04344 seconds
Time After: 0.05241 seconds
Time Taken: 0.00896 seconds
Time Before: 0.06617 seconds
Time After: 0.06661 seconds
Time Before: 0.06877 seconds
Time After: 0.07101 seconds
Time Taken: 0.00224 seconds
Time Before: 0.06539 seconds
Time After: 0.07126 seconds
Time Taken: 0.00586 seconds
Time Before: 0.12331 seconds
Time After: 0.12348 seconds
Time Before: 0.15043 seconds
Time After: 0.15171 seconds
Time Before: 0.15932 seconds
Time After: 0.15950 seconds
Time Before: 0.16196 seconds
Time After: 0.16387 seconds
Time Taken: 0.00190 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=57412', badlocation = 1 WHERE sessionhash = 'f88c536979e48fd20a608e8efaf90f77'
Time Before: 0.18237 seconds
Time After: 0.18267 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
