Time Before: 0.02770 seconds
Time After: 0.03566 seconds
Time Taken: 0.00797 seconds
Time Before: 0.03578 seconds
Time After: 0.03620 seconds
Time Before: 0.03652 seconds
Time After: 0.03669 seconds
Time Before: 0.03759 seconds
Time After: 0.03982 seconds
Time Taken: 0.00223 seconds
Time Before: 0.03676 seconds
Time After: 0.04391 seconds
Time Taken: 0.00714 seconds
Time Before: 0.04959 seconds
Time After: 0.04996 seconds
Time Before: 0.05269 seconds
Time After: 0.05388 seconds
Time Before: 0.04891 seconds
Time After: 0.05408 seconds
Time Taken: 0.00517 seconds
Time Before: 0.09883 seconds
Time After: 0.09897 seconds
Time Before: 0.12379 seconds
Time After: 0.12605 seconds
Time Taken: 0.00225 seconds
Time Before: 0.13888 seconds
Time After: 0.13942 seconds
Time Taken: 0.00055 seconds
Time Before: 0.14205 seconds
Time After: 0.14355 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=57515', badlocation = 1 WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.16321 seconds
Time After: 0.16345 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
