Time Before: 0.01686 seconds
Time After: 0.02374 seconds
Time Taken: 0.00688 seconds
Time Before: 0.02385 seconds
Time After: 0.02445 seconds
Time Taken: 0.00060 seconds
Time Before: 0.02474 seconds
Time After: 0.02490 seconds
Time Before: 0.02580 seconds
Time After: 0.02856 seconds
Time Taken: 0.00276 seconds
Time Before: 0.02498 seconds
Time After: 0.03303 seconds
Time Taken: 0.00806 seconds
Time Before: 0.04145 seconds
Time After: 0.04184 seconds
Time Before: 0.04438 seconds
Time After: 0.04577 seconds
Time Taken: 0.00140 seconds
Time Before: 0.04079 seconds
Time After: 0.04600 seconds
Time Taken: 0.00522 seconds
Time Before: 0.08453 seconds
Time After: 0.08468 seconds
Time Before: 0.12085 seconds
Time After: 0.12209 seconds
Time Before: 0.13061 seconds
Time After: 0.13082 seconds
Time Before: 0.13343 seconds
Time After: 0.13489 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=57522', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.15470 seconds
Time After: 0.15499 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
