Time Before: 0.02063 seconds
Time After: 0.02870 seconds
Time Taken: 0.00806 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02881 seconds
Time After: 0.02928 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02960 seconds
Time After: 0.02976 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03060 seconds
Time After: 0.03451 seconds
Time Taken: 0.00391 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02983 seconds
Time After: 0.03838 seconds
Time Taken: 0.00855 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04792 seconds
Time After: 0.04839 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05081 seconds
Time After: 0.05202 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04725 seconds
Time After: 0.05225 seconds
Time Taken: 0.00500 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.10241 seconds
Time After: 0.10260 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.17657 seconds
Time After: 0.17847 seconds
Time Taken: 0.00190 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.21238 seconds
Time After: 0.21254 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.22115 seconds
Time After: 0.22271 seconds
Time Taken: 0.00156 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1772675234, location = '/forums/private.php?do=newpm&explain=1&u=57537', badlocation = 1 WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.25512 seconds
Time After: 0.25555 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
