Time Before: 0.01642 seconds
Time After: 0.02511 seconds
Time Taken: 0.00868 seconds
Time Before: 0.02520 seconds
Time After: 0.02571 seconds
Time Before: 0.02596 seconds
Time After: 0.02611 seconds
Time Before: 0.02688 seconds
Time After: 0.03025 seconds
Time Taken: 0.00336 seconds
Time Before: 0.02618 seconds
Time After: 0.03428 seconds
Time Taken: 0.00809 seconds
Time Before: 0.04495 seconds
Time After: 0.04535 seconds
Time Before: 0.04797 seconds
Time After: 0.04922 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04420 seconds
Time After: 0.04941 seconds
Time Taken: 0.00520 seconds
Memory After: 2,261.719 KB
Time Before: 0.06945 seconds
Time After: 0.06960 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.09244 seconds
Time After: 0.09369 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.096703052520752
Time Before: 0.10568 seconds
Time After: 0.10585 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.10817 seconds
Time After: 0.11042 seconds
Time Taken: 0.00225 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=57603'
Time Before: 0.12988 seconds
Time After: 0.13014 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.12891697883606 seconds with 9 queries, spending 0.0097429752349854 doing MySQL queries and 0.11917400360107 doing PHP things.
