Time Before: 0.02078 seconds
Time After: 0.02701 seconds
Time Taken: 0.00623 seconds
Time Before: 0.02709 seconds
Time After: 0.02753 seconds
Time Before: 0.02781 seconds
Time After: 0.02799 seconds
Time Before: 0.02880 seconds
Time After: 0.03123 seconds
Time Taken: 0.00243 seconds
Time Before: 0.02806 seconds
Time After: 0.03535 seconds
Time Taken: 0.00729 seconds
Time Before: 0.04495 seconds
Time After: 0.04536 seconds
Time Before: 0.04775 seconds
Time After: 0.04898 seconds
Time Before: 0.04409 seconds
Time After: 0.04921 seconds
Time Taken: 0.00513 seconds
Time Before: 0.06936 seconds
Time After: 0.06953 seconds
Time Before: 0.08736 seconds
Time After: 0.08887 seconds
Time Taken: 0.00151 seconds
End call of global.php: 0.092015027999878
Time Before: 0.10552 seconds
Time After: 0.10569 seconds
Time Before: 0.10808 seconds
Time After: 0.10958 seconds
SET lastactivity = 1776901963, location = '/forums/private.php?do=newpm&explain=1&u=57664'
Time Before: 0.13264 seconds
Time After: 0.13295 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.13134789466858 seconds with 9 queries, spending 0.0083382129669189 doing MySQL queries and 0.12300968170166 doing PHP things.
