Time Before: 0.01385 seconds
Time After: 0.02176 seconds
Time Taken: 0.00791 seconds
Time Before: 0.02186 seconds
Time After: 0.02238 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02263 seconds
Time After: 0.02277 seconds
Time Before: 0.02357 seconds
Time After: 0.02575 seconds
Time Taken: 0.00218 seconds
Time Before: 0.02283 seconds
Time After: 0.02981 seconds
Time Taken: 0.00698 seconds
Time Before: 0.03729 seconds
Time After: 0.03767 seconds
Time Before: 0.04021 seconds
Time After: 0.04141 seconds
Time Before: 0.03652 seconds
Time After: 0.04161 seconds
Time Taken: 0.00509 seconds
Time Before: 0.08185 seconds
Time After: 0.08202 seconds
Time Before: 0.10271 seconds
Time After: 0.10402 seconds
Time Taken: 0.00131 seconds
Time Before: 0.11208 seconds
Time After: 0.11229 seconds
Time Before: 0.11507 seconds
Time After: 0.11661 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=5768' WHERE sessionhash = '86fb755ccb69fa1491ac644ca6ebf439'
Time Before: 0.13753 seconds
Time After: 0.13784 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.836 KB
Memory Used: 0.250 KB
