Time Before: 0.00174 seconds
Time After: 0.00225 seconds
Time Before: 0.00233 seconds
Time After: 0.00284 seconds
Time Before: 0.00320 seconds
Time After: 0.00334 seconds
Time Before: 0.00406 seconds
Time After: 0.00685 seconds
Time Taken: 0.00279 seconds
Time Before: 0.00342 seconds
Time After: 0.01025 seconds
Time Taken: 0.00683 seconds
Time Before: 0.01206 seconds
Time After: 0.01246 seconds
Time Before: 0.01485 seconds
Time After: 0.01607 seconds
Time Before: 0.01150 seconds
Time After: 0.01624 seconds
Time Taken: 0.00474 seconds
Time Before: 0.02253 seconds
Time After: 0.02268 seconds
Time Before: 0.02458 seconds
Time After: 0.02585 seconds
End call of global.php: 0.028100967407227
Time Before: 0.02931 seconds
Time After: 0.02945 seconds
Time Before: 0.03152 seconds
Time After: 0.03297 seconds
SET lastactivity = 1788948091, location = '/forums/private.php?do=newpm&explain=1&u=57726'
Time Before: 0.04701 seconds
Time After: 0.04734 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.046018123626709 seconds with 9 queries, spending 0.0083878040313721 doing MySQL queries and 0.037630319595337 doing PHP things.
