Time Before: 0.02303 seconds
Time After: 0.03051 seconds
Time Taken: 0.00747 seconds
Time Before: 0.03062 seconds
Time After: 0.03107 seconds
Time Before: 0.03134 seconds
Time After: 0.03145 seconds
Time Before: 0.03238 seconds
Time After: 0.03570 seconds
Time Taken: 0.00332 seconds
Time Before: 0.03153 seconds
Time After: 0.04136 seconds
Time Taken: 0.00983 seconds
Time Before: 0.04989 seconds
Time After: 0.05011 seconds
Time Before: 0.05240 seconds
Time After: 0.05358 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04921 seconds
Time After: 0.05380 seconds
Time Taken: 0.00459 seconds
Time Before: 0.09248 seconds
Time After: 0.09260 seconds
Time Before: 1.72598 seconds
Time After: 1.72763 seconds
Time Taken: 0.00165 seconds
End call of global.php: 1.7298231124878
Time Before: 1.73488 seconds
Time After: 1.73501 seconds
Time Before: 1.73725 seconds
Time After: 1.73876 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1777222479, location = '/forums/private.php?do=newpm&explain=1&u=57850', badlocation = 1
WHERE sessionhash = 'e9b85940693e8ec450606894f10508c2'
Time Before: 1.75809 seconds
Time After: 1.75836 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 1.7566759586334 seconds with 9 queries, spending 0.0089547634124756 doing MySQL queries and 1.7477211952209 doing PHP things.
