Time Before: 0.01597 seconds
Time After: 0.02031 seconds
Time Taken: 0.00434 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02041 seconds
Time After: 0.02088 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02120 seconds
Time After: 0.02135 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02224 seconds
Time After: 0.02462 seconds
Time Taken: 0.00238 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02141 seconds
Time After: 0.02890 seconds
Time Taken: 0.00749 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03554 seconds
Time After: 0.03620 seconds
Time Taken: 0.00066 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.03912 seconds
Time After: 0.04038 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03468 seconds
Time After: 0.04061 seconds
Time Taken: 0.00593 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.06557 seconds
Time After: 0.06570 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.10219 seconds
Time After: 0.10357 seconds
Time Taken: 0.00138 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.10596799850464
Time Before: 0.12360 seconds
Time After: 0.12375 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.12767 seconds
Time After: 0.12912 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=57866'
Time Before: 0.15145 seconds
Time After: 0.15173 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
Page generated in 0.1505138874054 seconds with 9 queries, spending 0.0083038806915283 doing MySQL queries and 0.14221000671387 doing PHP things.
