Time Before: 0.00217 seconds
Time After: 0.00293 seconds
Time Taken: 0.00076 seconds
Time Before: 0.00304 seconds
Time After: 0.00355 seconds
Time Before: 0.00380 seconds
Time After: 0.00393 seconds
Time Before: 0.00479 seconds
Time After: 0.00796 seconds
Time Taken: 0.00317 seconds
Time Before: 0.00401 seconds
Time After: 0.01271 seconds
Time Taken: 0.00870 seconds
Time Before: 0.01483 seconds
Time After: 0.01527 seconds
Time Before: 0.01802 seconds
Time After: 0.01923 seconds
Time Before: 0.01407 seconds
Time After: 0.01947 seconds
Time Taken: 0.00539 seconds
Time Before: 0.02499 seconds
Time After: 0.02517 seconds
Time Before: 0.02716 seconds
Time After: 0.02837 seconds
Time Before: 0.03136 seconds
Time After: 0.03156 seconds
Time Before: 0.03443 seconds
Time After: 0.03591 seconds
UPDATE session SET lastactivity = 1782953084, location = '/forums/private.php?do=newpm&explain=1&u=57881', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.05066 seconds
Time After: 0.05093 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
