Time Before: 0.00155 seconds
Time After: 0.00205 seconds
Time Before: 0.00212 seconds
Time After: 0.00257 seconds
Time Before: 0.00279 seconds
Time After: 0.00291 seconds
Time Before: 0.00363 seconds
Time After: 0.00606 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00297 seconds
Time After: 0.00949 seconds
Time Taken: 0.00652 seconds
Time Before: 0.01139 seconds
Time After: 0.01176 seconds
Time Before: 0.01429 seconds
Time After: 0.01545 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01078 seconds
Time After: 0.01565 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02098 seconds
Time After: 0.02114 seconds
Time Before: 0.02309 seconds
Time After: 0.02432 seconds
End call of global.php: 0.025953054428101
Time Before: 0.02717 seconds
Time After: 0.02730 seconds
Time Before: 0.02923 seconds
Time After: 0.03067 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=57928', badlocation = 1
Time Before: 0.04303 seconds
Time After: 0.04330 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.042128086090088 seconds with 9 queries, spending 0.0077469348907471 doing MySQL queries and 0.034381151199341 doing PHP things.
