Time Before: 0.00139 seconds
Time After: 0.00192 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00199 seconds
Time After: 0.00240 seconds
Time Before: 0.00261 seconds
Time After: 0.00315 seconds
Time Before: 0.00400 seconds
Time After: 0.00629 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00322 seconds
Time After: 0.00993 seconds
Time Taken: 0.00670 seconds
Time Before: 0.01205 seconds
Time After: 0.01248 seconds
Time Before: 0.01531 seconds
Time After: 0.01659 seconds
Time Before: 0.01144 seconds
Time After: 0.01677 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02247 seconds
Time After: 0.02260 seconds
Time Before: 0.02473 seconds
Time After: 0.02596 seconds
End call of global.php: 0.028100967407227
Time Before: 0.02919 seconds
Time After: 0.02931 seconds
Time Before: 0.03124 seconds
Time After: 0.03316 seconds
Time Taken: 0.00192 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=58079'
Time Before: 0.04833 seconds
Time After: 0.04869 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.047430992126465 seconds with 9 queries, spending 0.0087082386016846 doing MySQL queries and 0.03872275352478 doing PHP things.
