Time Before: 0.02854 seconds
Time After: 0.03601 seconds
Time Taken: 0.00748 seconds
Time Before: 0.03610 seconds
Time After: 0.03651 seconds
Time Before: 0.03677 seconds
Time After: 0.03692 seconds
Time Before: 0.03780 seconds
Time After: 0.03981 seconds
Time Taken: 0.00202 seconds
Time Before: 0.03698 seconds
Time After: 0.04401 seconds
Time Taken: 0.00703 seconds
Time Before: 0.05105 seconds
Time After: 0.05160 seconds
Time Taken: 0.00055 seconds
Time Before: 0.05477 seconds
Time After: 0.05618 seconds
Time Before: 0.05032 seconds
Time After: 0.05645 seconds
Time Taken: 0.00613 seconds
Time Before: 0.10232 seconds
Time After: 0.10246 seconds
Time Before: 0.12094 seconds
Time After: 0.12218 seconds
End call of global.php: 0.12411499023438
Time Before: 0.14035 seconds
Time After: 0.14049 seconds
Time Before: 0.14304 seconds
Time After: 0.14451 seconds
SET lastactivity = 1776583180, location = '/forums/private.php?do=newpm&explain=1&u=58195'
Time Before: 0.16200 seconds
Time After: 0.16230 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.16104197502136 seconds with 9 queries, spending 0.0078322887420654 doing MySQL queries and 0.1532096862793 doing PHP things.
