Time Before: 0.00169 seconds
Time After: 0.00291 seconds
Time Before: 0.00298 seconds
Time After: 0.00341 seconds
Time Before: 0.00365 seconds
Time After: 0.00378 seconds
Time Before: 0.00475 seconds
Time After: 0.00784 seconds
Time Taken: 0.00309 seconds
Time Before: 0.00386 seconds
Time After: 0.01298 seconds
Time Taken: 0.00912 seconds
Time Before: 0.01643 seconds
Time After: 0.01688 seconds
Time Before: 0.02030 seconds
Time After: 0.02150 seconds
Time Before: 0.01535 seconds
Time After: 0.02178 seconds
Time Taken: 0.00643 seconds
Time Before: 0.02864 seconds
Time After: 0.02882 seconds
Time Before: 0.03213 seconds
Time After: 0.03359 seconds
End call of global.php: 0.035845041275024
Time Before: 0.03713 seconds
Time After: 0.03734 seconds
Time Before: 0.03991 seconds
Time After: 0.04137 seconds
SET lastactivity = 1788955067, location = '/forums/private.php?do=newpm&explain=1&u=58204'
Time Before: 0.05398 seconds
Time After: 0.05431 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.053026914596558 seconds with 9 queries, spending 0.0089271068572998 doing MySQL queries and 0.044099807739258 doing PHP things.
