Time Before: 0.00588 seconds
Time After: 0.00775 seconds
Time Taken: 0.00187 seconds
Time Before: 0.00786 seconds
Time After: 0.00827 seconds
Time Before: 0.00849 seconds
Time After: 0.00859 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00928 seconds
Time After: 0.01190 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00864 seconds
Time After: 0.01532 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01758 seconds
Time After: 0.01779 seconds
Time Before: 0.02029 seconds
Time After: 0.02149 seconds
Time Before: 0.01698 seconds
Time After: 0.02166 seconds
Time Taken: 0.00467 seconds
Time Before: 0.03268 seconds
Time After: 0.03279 seconds
Time Before: 0.03677 seconds
Time After: 0.03800 seconds
Time Before: 0.04219 seconds
Time After: 0.04244 seconds
Time Before: 0.04441 seconds
Time After: 0.04583 seconds
UPDATE session SET lastactivity = 1782883469, location = '/forums/private.php?do=newpm&explain=1&u=5827' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.05873 seconds
Time After: 0.05899 seconds
Memory Before: 4,288.281 KB
Memory After: 4,288.500 KB
