Time Before: 0.01578 seconds
Time After: 0.02174 seconds
Time Taken: 0.00596 seconds
Time Before: 0.02184 seconds
Time After: 0.02224 seconds
Time Before: 0.02243 seconds
Time After: 0.02256 seconds
Time Before: 0.02344 seconds
Time After: 0.02563 seconds
Time Taken: 0.00220 seconds
Time Before: 0.02264 seconds
Time After: 0.02987 seconds
Time Taken: 0.00722 seconds
Time Before: 0.03918 seconds
Time After: 0.03964 seconds
Time Before: 0.04122 seconds
Time After: 0.04330 seconds
Time Taken: 0.00208 seconds
Time Before: 0.03855 seconds
Time After: 0.04352 seconds
Time Taken: 0.00497 seconds
Time Before: 0.07379 seconds
Time After: 0.07392 seconds
Time Before: 0.09143 seconds
Time After: 0.09266 seconds
End call of global.php: 0.09471607208252
Time Before: 0.10490 seconds
Time After: 0.10504 seconds
Time Before: 0.10755 seconds
Time After: 0.10896 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=58276', badlocation = 1
Time Before: 0.12684 seconds
Time After: 0.12708 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.12573790550232 seconds with 9 queries, spending 0.0084145069122314 doing MySQL queries and 0.11732339859009 doing PHP things.
