Time Before: 0.00168 seconds
Time After: 0.00219 seconds
Time Before: 0.00226 seconds
Time After: 0.00267 seconds
Time Before: 0.00288 seconds
Time After: 0.00299 seconds
Time Before: 0.00366 seconds
Time After: 0.00636 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00304 seconds
Time After: 0.00991 seconds
Time Taken: 0.00687 seconds
Time Before: 0.01198 seconds
Time After: 0.01238 seconds
Time Before: 0.01481 seconds
Time After: 0.01598 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01137 seconds
Time After: 0.01616 seconds
Time Taken: 0.00478 seconds
Memory After: 2,261.836 KB
Time Before: 0.02106 seconds
Time After: 0.02120 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02336 seconds
Time After: 0.02461 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.026637077331543
Time Before: 0.02788 seconds
Time After: 0.02802 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03009 seconds
Time After: 0.03265 seconds
Time Taken: 0.00256 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789093019, location = '/forums/private.php?do=newpm&explain=1&u=58324'
Time Before: 0.04516 seconds
Time After: 0.04549 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.04425311088562 seconds with 9 queries, spending 0.0092265605926514 doing MySQL queries and 0.035026550292969 doing PHP things.
