Time Before: 0.00608 seconds
Time After: 0.00739 seconds
Time Taken: 0.00132 seconds
Time Before: 0.00746 seconds
Time After: 0.00799 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00823 seconds
Time After: 0.00840 seconds
Time Before: 0.00907 seconds
Time After: 0.01185 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00845 seconds
Time After: 0.01526 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01899 seconds
Time After: 0.01926 seconds
Time Before: 0.02162 seconds
Time After: 0.02431 seconds
Time Taken: 0.00269 seconds
Time Before: 0.01833 seconds
Time After: 0.02448 seconds
Time Taken: 0.00614 seconds
Time Before: 0.03773 seconds
Time After: 0.03792 seconds
Time Before: 0.04266 seconds
Time After: 0.04393 seconds
Time Before: 0.04980 seconds
Time After: 0.05043 seconds
Time Taken: 0.00064 seconds
Time Before: 0.05312 seconds
Time After: 0.05512 seconds
Time Taken: 0.00200 seconds
UPDATE session SET lastactivity = 1783649816, location = '/forums/private.php?do=newpm&explain=1&u=58349', badlocation = 1 WHERE sessionhash = 'b1e9f976e3e130f3a0e1c3e688e54b68'
Time Before: 0.07399 seconds
Time After: 0.07431 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
