Time Before: 0.00134 seconds
Time After: 0.00188 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00195 seconds
Time After: 0.00244 seconds
Time Before: 0.00268 seconds
Time After: 0.00283 seconds
Time Before: 0.00352 seconds
Time After: 0.00629 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00288 seconds
Time After: 0.01064 seconds
Time Taken: 0.00776 seconds
Time Before: 0.01251 seconds
Time After: 0.01289 seconds
Time Before: 0.01424 seconds
Time After: 0.01549 seconds
Time Before: 0.01192 seconds
Time After: 0.01575 seconds
Time Taken: 0.00383 seconds
Time Before: 0.02128 seconds
Time After: 0.02143 seconds
Time Before: 0.02368 seconds
Time After: 0.02492 seconds
End call of global.php: 0.027753829956055
Time Before: 0.02912 seconds
Time After: 0.02926 seconds
Time Before: 0.03233 seconds
Time After: 0.03381 seconds
SET lastactivity = 1776652465, location = '/forums/private.php?do=newpm&explain=1&u=58352'
Time Before: 0.04915 seconds
Time After: 0.04945 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.048208951950073 seconds with 9 queries, spending 0.0083498954772949 doing MySQL queries and 0.039859056472778 doing PHP things.
