Time Before: 0.01782 seconds
Time After: 0.02339 seconds
Time Taken: 0.00557 seconds
Time Before: 0.02350 seconds
Time After: 0.02453 seconds
Time Taken: 0.00103 seconds
Time Before: 0.02507 seconds
Time After: 0.02523 seconds
Time Before: 0.02602 seconds
Time After: 0.03126 seconds
Time Taken: 0.00525 seconds
Time Before: 0.02530 seconds
Time After: 0.03577 seconds
Time Taken: 0.01047 seconds
Time Before: 0.05231 seconds
Time After: 0.05342 seconds
Time Taken: 0.00111 seconds
Time Before: 0.05579 seconds
Time After: 0.05920 seconds
Time Taken: 0.00341 seconds
Time Before: 0.05088 seconds
Time After: 0.05947 seconds
Time Taken: 0.00859 seconds
Time Before: 0.09926 seconds
Time After: 0.09952 seconds
Time Before: 0.67385 seconds
Time After: 0.67550 seconds
Time Taken: 0.00165 seconds
Time Before: 0.68983 seconds
Time After: 0.69003 seconds
Time Before: 0.69273 seconds
Time After: 0.69425 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1776702860, location = '/forums/private.php?do=newpm&explain=1&u=58540', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.71386 seconds
Time After: 0.71411 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
