Time Before: 0.00208 seconds
Time After: 0.00269 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00277 seconds
Time After: 0.00328 seconds
Time Before: 0.00348 seconds
Time After: 0.00363 seconds
Time Before: 0.00433 seconds
Time After: 0.00689 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00370 seconds
Time After: 0.01026 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01263 seconds
Time After: 0.01298 seconds
Time Before: 0.01532 seconds
Time After: 0.01652 seconds
Time Before: 0.01196 seconds
Time After: 0.01678 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02249 seconds
Time After: 0.02267 seconds
Time Before: 0.02485 seconds
Time After: 0.02607 seconds
Time Before: 0.02882 seconds
Time After: 0.02899 seconds
Time Before: 0.03101 seconds
Time After: 0.03245 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=58637', badlocation = 1 WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.04640 seconds
Time After: 0.04671 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
