Time Before: 0.00142 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00241 seconds
Time Before: 0.00259 seconds
Time After: 0.00271 seconds
Time Before: 0.00338 seconds
Time After: 0.00602 seconds
Time Taken: 0.00263 seconds
Time Before: 0.00276 seconds
Time After: 0.00947 seconds
Time Taken: 0.00672 seconds
Time Before: 0.01167 seconds
Time After: 0.01235 seconds
Time Taken: 0.00068 seconds
Time Before: 0.01480 seconds
Time After: 0.01604 seconds
Time Before: 0.01088 seconds
Time After: 0.01623 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02130 seconds
Time After: 0.02145 seconds
Time Before: 0.02373 seconds
Time After: 0.02509 seconds
Time Taken: 0.00136 seconds
Time Before: 0.02829 seconds
Time After: 0.02844 seconds
Time Before: 0.03073 seconds
Time After: 0.03217 seconds
UPDATE session SET lastactivity = 1776973504, location = '/forums/private.php?do=newpm&explain=1&u=5866' WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.04514 seconds
Time After: 0.04556 seconds
Memory Before: 4,911.898 KB
Memory After: 4,912.117 KB
