Time Before: 0.00380 seconds
Time After: 0.00609 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00618 seconds
Time After: 0.00659 seconds
Time Before: 0.00686 seconds
Time After: 0.00701 seconds
Time Before: 0.00784 seconds
Time After: 0.01026 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00708 seconds
Time After: 0.01465 seconds
Time Taken: 0.00756 seconds
Time Before: 0.01902 seconds
Time After: 0.01941 seconds
Time Before: 0.02196 seconds
Time After: 0.02343 seconds
Time Before: 0.01839 seconds
Time After: 0.02364 seconds
Time Taken: 0.00525 seconds
Time Before: 0.03611 seconds
Time After: 0.03626 seconds
Time Before: 0.04071 seconds
Time After: 0.04196 seconds
End call of global.php: 0.043672800064087
Time Before: 0.04606 seconds
Time After: 0.04621 seconds
Time Before: 0.04915 seconds
Time After: 0.05059 seconds
SET lastactivity = 1777007434, location = '/forums/private.php?do=newpm&explain=1&u=58661'
WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.06759 seconds
Time After: 0.06790 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.066432952880859 seconds with 9 queries, spending 0.0081260204315186 doing MySQL queries and 0.058306932449341 doing PHP things.
