Time Before: 0.02733 seconds
Time After: 0.03657 seconds
Time Taken: 0.00924 seconds
Time Before: 0.03670 seconds
Time After: 0.03713 seconds
Time Before: 0.03742 seconds
Time After: 0.03758 seconds
Time Before: 0.03856 seconds
Time After: 0.04087 seconds
Time Taken: 0.00231 seconds
Time Before: 0.03766 seconds
Time After: 0.04637 seconds
Time Taken: 0.00870 seconds
Time Before: 0.05650 seconds
Time After: 0.05689 seconds
Time Before: 0.05847 seconds
Time After: 0.05965 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05576 seconds
Time After: 0.05982 seconds
Time Taken: 0.00406 seconds
Time Before: 0.10365 seconds
Time After: 0.10379 seconds
Time Before: 0.88043 seconds
Time After: 0.88221 seconds
Time Taken: 0.00178 seconds
Time Before: 0.89269 seconds
Time After: 0.89284 seconds
Time Before: 0.89534 seconds
Time After: 0.89712 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=58672' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.91540 seconds
Time After: 0.91565 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
