Time Before: 0.00242 seconds
Time After: 0.00293 seconds
Time Before: 0.00300 seconds
Time After: 0.00349 seconds
Time Before: 0.00378 seconds
Time After: 0.00394 seconds
Time Before: 0.00478 seconds
Time After: 0.00857 seconds
Time Taken: 0.00379 seconds
Time Before: 0.00402 seconds
Time After: 0.01329 seconds
Time Taken: 0.00927 seconds
Time Before: 0.01546 seconds
Time After: 0.01595 seconds
Time Before: 0.01733 seconds
Time After: 0.01873 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01481 seconds
Time After: 0.01890 seconds
Time Taken: 0.00409 seconds
Time Before: 0.02384 seconds
Time After: 0.02406 seconds
Time Before: 0.02600 seconds
Time After: 0.02725 seconds
End call of global.php: 0.02885890007019
Time Before: 0.02991 seconds
Time After: 0.03007 seconds
Time Before: 0.03206 seconds
Time After: 0.03353 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=58751'
Time Before: 0.04586 seconds
Time After: 0.04619 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.044955968856812 seconds with 9 queries, spending 0.009742259979248 doing MySQL queries and 0.035213708877563 doing PHP things.
