Time Before: 0.00135 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00243 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00268 seconds
Time After: 0.00282 seconds
Time Before: 0.00345 seconds
Time After: 0.00615 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00287 seconds
Time After: 0.01096 seconds
Time Taken: 0.00809 seconds
Time Before: 0.01333 seconds
Time After: 0.01382 seconds
Time Before: 0.01527 seconds
Time After: 0.01668 seconds
Time Before: 0.01257 seconds
Time After: 0.01686 seconds
Time Taken: 0.00429 seconds
Time Before: 0.02191 seconds
Time After: 0.02205 seconds
Time Before: 0.02386 seconds
Time After: 0.02510 seconds
End call of global.php: 0.026715040206909
Time Before: 0.02807 seconds
Time After: 0.02829 seconds
Time Before: 0.03025 seconds
Time After: 0.03169 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=58810'
Time Before: 0.04420 seconds
Time After: 0.04443 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.043298959732056 seconds with 9 queries, spending 0.0085508823394775 doing MySQL queries and 0.034748077392578 doing PHP things.
