Time Before: 0.00277 seconds
Time After: 0.00338 seconds
Time Taken: 0.00061 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00345 seconds
Time After: 0.00393 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00419 seconds
Time After: 0.00439 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00516 seconds
Time After: 0.00841 seconds
Time Taken: 0.00325 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00446 seconds
Time After: 0.01182 seconds
Time Taken: 0.00736 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01390 seconds
Time After: 0.01432 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01666 seconds
Time After: 0.01807 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01330 seconds
Time After: 0.01826 seconds
Time Taken: 0.00496 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02502 seconds
Time After: 0.02518 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.03241 seconds
Time After: 0.03381 seconds
Time Taken: 0.00140 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.04206 seconds
Time After: 0.04229 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.04454 seconds
Time After: 0.04606 seconds
Time Taken: 0.00153 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=58840' WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.05945 seconds
Time After: 0.05977 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
