Time Before: 0.00188 seconds
Time After: 0.00245 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00256 seconds
Time After: 0.00333 seconds
Time Taken: 0.00078 seconds
Time Before: 0.00386 seconds
Time After: 0.00399 seconds
Time Before: 0.00489 seconds
Time After: 0.00725 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00407 seconds
Time After: 0.01107 seconds
Time Taken: 0.00700 seconds
Time Before: 0.01311 seconds
Time After: 0.01358 seconds
Time Before: 0.01535 seconds
Time After: 0.01655 seconds
Time Before: 0.01226 seconds
Time After: 0.01685 seconds
Time Taken: 0.00459 seconds
Time Before: 0.02284 seconds
Time After: 0.02296 seconds
Time Before: 0.02471 seconds
Time After: 0.02592 seconds
End call of global.php: 0.027605056762695
Time Before: 0.02900 seconds
Time After: 0.02916 seconds
Time Before: 0.03223 seconds
Time After: 0.03379 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1782992168, location = '/forums/private.php?do=newpm&explain=1&u=58906'
Time Before: 0.04798 seconds
Time After: 0.04833 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.047021150588989 seconds with 9 queries, spending 0.0083267688751221 doing MySQL queries and 0.038694381713867 doing PHP things.
