Time Before: 0.00132 seconds
Time After: 0.00179 seconds
Time Before: 0.00187 seconds
Time After: 0.00226 seconds
Time Before: 0.00246 seconds
Time After: 0.00258 seconds
Time Before: 0.00331 seconds
Time After: 0.00614 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00262 seconds
Time After: 0.01113 seconds
Time Taken: 0.00851 seconds
Time Before: 0.01333 seconds
Time After: 0.01380 seconds
Time Before: 0.01710 seconds
Time After: 0.01832 seconds
Time Before: 0.01258 seconds
Time After: 0.01851 seconds
Time Taken: 0.00593 seconds
Time Before: 0.02468 seconds
Time After: 0.02481 seconds
Time Before: 0.02670 seconds
Time After: 0.02795 seconds
Time Before: 0.03105 seconds
Time After: 0.03128 seconds
Time Before: 0.03337 seconds
Time After: 0.03483 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=58913', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.04908 seconds
Time After: 0.04936 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
