Time Before: 0.00135 seconds
Time After: 0.00179 seconds
Time Before: 0.00185 seconds
Time After: 0.00230 seconds
Time Before: 0.00255 seconds
Time After: 0.00268 seconds
Time Before: 0.00361 seconds
Time After: 0.00635 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00276 seconds
Time After: 0.01139 seconds
Time Taken: 0.00863 seconds
Time Before: 0.01342 seconds
Time After: 0.01385 seconds
Time Before: 0.01720 seconds
Time After: 0.01846 seconds
Time Before: 0.01265 seconds
Time After: 0.01863 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02373 seconds
Time After: 0.02385 seconds
Time Before: 0.02582 seconds
Time After: 0.02704 seconds
End call of global.php: 0.028707027435303
Time Before: 0.02999 seconds
Time After: 0.03017 seconds
Time Before: 0.03232 seconds
Time After: 0.03377 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=58947'
Time Before: 0.04914 seconds
Time After: 0.04951 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.048218965530396 seconds with 9 queries, spending 0.0083613395690918 doing MySQL queries and 0.039857625961304 doing PHP things.
