Time Before: 0.00245 seconds
Time After: 0.00300 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00308 seconds
Time After: 0.00348 seconds
Time Before: 0.00385 seconds
Time After: 0.00398 seconds
Time Before: 0.00472 seconds
Time After: 0.00721 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00402 seconds
Time After: 0.01242 seconds
Time Taken: 0.00840 seconds
Time Before: 0.01435 seconds
Time After: 0.01471 seconds
Time Before: 0.01710 seconds
Time After: 0.01845 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01379 seconds
Time After: 0.01863 seconds
Time Taken: 0.00484 seconds
Memory After: 2,261.719 KB
Time Before: 0.02407 seconds
Time After: 0.02429 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02622 seconds
Time After: 0.02747 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.029153108596802
Time Before: 0.03091 seconds
Time After: 0.03114 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03329 seconds
Time After: 0.03478 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=58976'
Time Before: 0.04770 seconds
Time After: 0.04809 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.046780109405518 seconds with 9 queries, spending 0.0083096027374268 doing MySQL queries and 0.038470506668091 doing PHP things.
