Time Before: 0.02020 seconds
Time After: 0.02794 seconds
Time Taken: 0.00774 seconds
Time Before: 0.02803 seconds
Time After: 0.02853 seconds
Time Before: 0.02876 seconds
Time After: 0.02893 seconds
Time Before: 0.02983 seconds
Time After: 0.03211 seconds
Time Taken: 0.00228 seconds
Time Before: 0.02903 seconds
Time After: 0.03669 seconds
Time Taken: 0.00766 seconds
Time Before: 0.04538 seconds
Time After: 0.04580 seconds
Time Before: 0.04789 seconds
Time After: 0.04909 seconds
Time Before: 0.04470 seconds
Time After: 0.04933 seconds
Time Taken: 0.00463 seconds
Time Before: 0.07824 seconds
Time After: 0.07841 seconds
Time Before: 0.09379 seconds
Time After: 0.09499 seconds
Time Before: 0.10532 seconds
Time After: 0.10555 seconds
Time Before: 0.10864 seconds
Time After: 0.11014 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=59060', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.12796 seconds
Time After: 0.12826 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
