Time Before: 0.00172 seconds
Time After: 0.00220 seconds
Time Before: 0.00227 seconds
Time After: 0.00278 seconds
Time Before: 0.00306 seconds
Time After: 0.00324 seconds
Time Before: 0.00413 seconds
Time After: 0.00707 seconds
Time Taken: 0.00294 seconds
Time Before: 0.00329 seconds
Time After: 0.01225 seconds
Time Taken: 0.00896 seconds
Time Before: 0.01497 seconds
Time After: 0.01545 seconds
Time Before: 0.01797 seconds
Time After: 0.01918 seconds
Time Before: 0.01423 seconds
Time After: 0.01935 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02484 seconds
Time After: 0.02500 seconds
Time Before: 0.02700 seconds
Time After: 0.02824 seconds
Time Before: 0.03202 seconds
Time After: 0.03220 seconds
Time Before: 0.03463 seconds
Time After: 0.03615 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1789119451, location = '/forums/private.php?do=newpm&explain=1&u=59077', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05634 seconds
Time After: 0.05689 seconds
Time Taken: 0.00056 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
