Time Before: 0.01433 seconds
Time After: 0.01802 seconds
Time Taken: 0.00369 seconds
Time Before: 0.01811 seconds
Time After: 0.01851 seconds
Time Before: 0.01875 seconds
Time After: 0.01890 seconds
Time Before: 0.01961 seconds
Time After: 0.02197 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01896 seconds
Time After: 0.02645 seconds
Time Taken: 0.00749 seconds
Time Before: 0.03281 seconds
Time After: 0.03324 seconds
Time Before: 0.03618 seconds
Time After: 0.03749 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03211 seconds
Time After: 0.03774 seconds
Time Taken: 0.00563 seconds
Time Before: 0.06202 seconds
Time After: 0.06217 seconds
Time Before: 0.07758 seconds
Time After: 0.07884 seconds
Time Before: 0.08684 seconds
Time After: 0.08702 seconds
Time Before: 0.09047 seconds
Time After: 0.09194 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=59162' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.11306 seconds
Time After: 0.11336 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
