Time Before: 0.00157 seconds
Time After: 0.00235 seconds
Time Taken: 0.00078 seconds
Time Before: 0.00242 seconds
Time After: 0.00279 seconds
Time Before: 0.00302 seconds
Time After: 0.00321 seconds
Time Before: 0.00413 seconds
Time After: 0.00650 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00328 seconds
Time After: 0.01166 seconds
Time Taken: 0.00838 seconds
Time Before: 0.01409 seconds
Time After: 0.01453 seconds
Time Before: 0.01750 seconds
Time After: 0.01880 seconds
Time Before: 0.01328 seconds
Time After: 0.01905 seconds
Time Taken: 0.00577 seconds
Time Before: 0.02592 seconds
Time After: 0.02606 seconds
Time Before: 0.02849 seconds
Time After: 0.02979 seconds
Time Before: 0.03388 seconds
Time After: 0.03403 seconds
Time Before: 0.03669 seconds
Time After: 0.03814 seconds
UPDATE session SET lastactivity = 1784896140, location = '/forums/private.php?do=newpm&explain=1&u=59261' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.05157 seconds
Time After: 0.05187 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
