Time Before: 0.01576 seconds
Time After: 0.02238 seconds
Time Taken: 0.00662 seconds
Time Before: 0.02248 seconds
Time After: 0.02300 seconds
Time Before: 0.02326 seconds
Time After: 0.02348 seconds
Time Before: 0.02424 seconds
Time After: 0.02713 seconds
Time Taken: 0.00289 seconds
Time Before: 0.02356 seconds
Time After: 0.03130 seconds
Time Taken: 0.00774 seconds
Time Before: 0.04031 seconds
Time After: 0.04073 seconds
Time Before: 0.04333 seconds
Time After: 0.04455 seconds
Time Before: 0.03964 seconds
Time After: 0.04479 seconds
Time Taken: 0.00515 seconds
Time Before: 0.07655 seconds
Time After: 0.07671 seconds
Time Before: 0.10018 seconds
Time After: 0.10149 seconds
Time Taken: 0.00131 seconds
Time Before: 0.11357 seconds
Time After: 0.11374 seconds
Time Before: 0.11618 seconds
Time After: 0.11766 seconds
UPDATE session SET lastactivity = 1776878700, location = '/forums/private.php?do=newpm&explain=1&u=59305', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.13712 seconds
Time After: 0.13743 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
