Time Before: 0.00178 seconds
Time After: 0.00227 seconds
Time Before: 0.00234 seconds
Time After: 0.00283 seconds
Time Before: 0.00321 seconds
Time After: 0.00334 seconds
Time Before: 0.00439 seconds
Time After: 0.00673 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00343 seconds
Time After: 0.01130 seconds
Time Taken: 0.00787 seconds
Time Before: 0.01338 seconds
Time After: 0.01374 seconds
Time Before: 0.01615 seconds
Time After: 0.01730 seconds
Time Taken: 0.00115 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01271 seconds
Time After: 0.01751 seconds
Time Taken: 0.00480 seconds
Memory After: 2,261.836 KB
Time Before: 0.02410 seconds
Time After: 0.02424 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02676 seconds
Time After: 0.02799 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.03234 seconds
Time After: 0.03276 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03549 seconds
Time After: 0.03717 seconds
Time Taken: 0.00168 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789028766, location = '/forums/private.php?do=newpm&explain=1&u=5932' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05252 seconds
Time After: 0.05289 seconds
Memory Before: 4,287.586 KB
Memory After: 4,287.805 KB
