Time Before: 0.00156 seconds
Time After: 0.00219 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00229 seconds
Time After: 0.00293 seconds
Time Before: 0.00321 seconds
Time After: 0.00340 seconds
Time Before: 0.00406 seconds
Time After: 0.00717 seconds
Time Taken: 0.00311 seconds
Time Before: 0.00346 seconds
Time After: 0.01055 seconds
Time Taken: 0.00709 seconds
Time Before: 0.01287 seconds
Time After: 0.01330 seconds
Time Before: 0.01572 seconds
Time After: 0.01736 seconds
Time Taken: 0.00164 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01219 seconds
Time After: 0.01754 seconds
Time Taken: 0.00535 seconds
Memory After: 2,261.719 KB
Time Before: 0.02309 seconds
Time After: 0.02334 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02534 seconds
Time After: 0.02660 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.028331995010376
Time Before: 0.02967 seconds
Time After: 0.02991 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03190 seconds
Time After: 0.03334 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=59459'
Time Before: 0.04572 seconds
Time After: 0.04605 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.044831991195679 seconds with 9 queries, spending 0.0095362663269043 doing MySQL queries and 0.035295724868774 doing PHP things.
