Time Before: 0.01445 seconds
Time After: 0.02179 seconds
Time Taken: 0.00734 seconds
Time Before: 0.02189 seconds
Time After: 0.02290 seconds
Time Taken: 0.00101 seconds
Time Before: 0.02325 seconds
Time After: 0.02427 seconds
Time Before: 0.02512 seconds
Time After: 0.02852 seconds
Time Taken: 0.00340 seconds
Time Before: 0.02432 seconds
Time After: 0.03277 seconds
Time Taken: 0.00845 seconds
Time Before: 0.04163 seconds
Time After: 0.04183 seconds
Time Before: 0.04457 seconds
Time After: 0.04642 seconds
Time Taken: 0.00185 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04099 seconds
Time After: 0.04664 seconds
Time Taken: 0.00565 seconds
Memory After: 2,261.719 KB
Time Before: 0.09497 seconds
Time After: 0.09510 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.12339 seconds
Time After: 0.12522 seconds
Time Taken: 0.00183 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.12826490402222
Time Before: 0.14192 seconds
Time After: 0.14210 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.14474 seconds
Time After: 0.14619 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=59541'
Time Before: 0.16401 seconds
Time After: 0.16431 seconds
Memory Before: 4,287.984 KB
Memory After: 4,288.227 KB
Page generated in 0.16298890113831 seconds with 9 queries, spending 0.011368989944458 doing MySQL queries and 0.15161991119385 doing PHP things.
