Time Before: 0.00154 seconds
Time After: 0.00207 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00214 seconds
Time After: 0.00276 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00297 seconds
Time After: 0.00311 seconds
Time Before: 0.00385 seconds
Time After: 0.00786 seconds
Time Taken: 0.00402 seconds
Time Before: 0.00316 seconds
Time After: 0.01121 seconds
Time Taken: 0.00805 seconds
Time Before: 0.01334 seconds
Time After: 0.01385 seconds
Time Before: 0.01693 seconds
Time After: 0.01819 seconds
Time Before: 0.01270 seconds
Time After: 0.01837 seconds
Time Taken: 0.00567 seconds
Time Before: 0.02363 seconds
Time After: 0.02377 seconds
Time Before: 0.02595 seconds
Time After: 0.02729 seconds
Time Taken: 0.00134 seconds
Time Before: 0.03097 seconds
Time After: 0.03111 seconds
Time Before: 0.03349 seconds
Time After: 0.03525 seconds
Time Taken: 0.00176 seconds
UPDATE session SET lastactivity = 1782961282, location = '/forums/private.php?do=newpm&explain=1&u=59663' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.05511 seconds
Time After: 0.05549 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
