Time Before: 0.00146 seconds
Time After: 0.00202 seconds
Time Taken: 0.00056 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00209 seconds
Time After: 0.00259 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00286 seconds
Time After: 0.00303 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00390 seconds
Time After: 0.00668 seconds
Time Taken: 0.00278 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00311 seconds
Time After: 0.01148 seconds
Time Taken: 0.00836 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01528 seconds
Time After: 0.01670 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.02004 seconds
Time After: 0.03075 seconds
Time Taken: 0.01070 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01357 seconds
Time After: 0.03104 seconds
Time Taken: 0.01747 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.04368 seconds
Time After: 0.04386 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.05274 seconds
Time After: 0.05420 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.056573152542114
Time Before: 0.06067 seconds
Time After: 0.06085 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.06370 seconds
Time After: 0.06516 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=59701'
Time Before: 0.08642 seconds
Time After: 0.08679 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.085021018981934 seconds with 9 queries, spending 0.019227981567383 doing MySQL queries and 0.065793037414551 doing PHP things.
