Time Before: 0.01210 seconds
Time After: 0.01959 seconds
Time Taken: 0.00749 seconds
Time Before: 0.01969 seconds
Time After: 0.02021 seconds
Time Before: 0.02048 seconds
Time After: 0.02084 seconds
Time Before: 0.02176 seconds
Time After: 0.02430 seconds
Time Taken: 0.00254 seconds
Time Before: 0.02091 seconds
Time After: 0.02840 seconds
Time Before: 0.03767 seconds
Time After: 0.03806 seconds
Time Before: 0.04060 seconds
Time After: 0.04189 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03698 seconds
Time After: 0.04208 seconds
Time Taken: 0.00510 seconds
Memory After: 2,261.836 KB
Time Before: 0.06140 seconds
Time After: 0.06156 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08077 seconds
Time After: 0.08214 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.09155 seconds
Time After: 0.09174 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.09462 seconds
Time After: 0.09608 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789069259, location = '/forums/private.php?do=newpm&explain=1&u=59742', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.11611 seconds
Time After: 0.11653 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
