Time Before: 0.02068 seconds
Time After: 0.02842 seconds
Time Taken: 0.00774 seconds
Time Before: 0.02849 seconds
Time After: 0.02890 seconds
Time Before: 0.02929 seconds
Time After: 0.02946 seconds
Time Before: 0.03019 seconds
Time After: 0.03210 seconds
Time Taken: 0.00191 seconds
Time Before: 0.02951 seconds
Time After: 0.03621 seconds
Time Taken: 0.00670 seconds
Time Before: 0.04348 seconds
Time After: 0.04389 seconds
Time Before: 0.04627 seconds
Time After: 0.04749 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04285 seconds
Time After: 0.04771 seconds
Time Taken: 0.00486 seconds
Memory After: 2,261.719 KB
Time Before: 0.08162 seconds
Time After: 0.08179 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.10352 seconds
Time After: 0.10479 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.10706400871277
Time Before: 0.11803 seconds
Time After: 0.11819 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12080 seconds
Time After: 0.12226 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=5989', badlocation = 1
Time Before: 0.13954 seconds
Time After: 0.14017 seconds
Time Taken: 0.00064 seconds
Memory Before: 4,287.508 KB
Memory After: 4,287.734 KB
Page generated in 0.13863587379456 seconds with 9 queries, spending 0.0078246593475342 doing MySQL queries and 0.13081121444702 doing PHP things.
